Post by Stinger on Oct 13, 2009 22:41:24 GMT -5
Hard to say whether the map/bap got hurt by the faulty wiring or not. Have you went through each sensor and verified that they have 5v, ground, (and in some cases a variable voltage) to the correct wires in each location?
The timing is controlled by a ton of things besides rpm (throttle position, air intake temp, load level, airflow, acceleration rate, etc.).
