selling my pimp ecu, firmware has been updated to 3.4. i have the startup/set up instructions in the flash drive with base tune, map hose, 4 jumpers and an enclosed expansion port connector for add ons. the tune in it is for my engine, e85, hot pinto cam, 1300 cc inj's, wes k cas ( cam angle sensor) system which is 24-2 toothed wheel like the 36-1 toothed wheel and ls coils. the base tune in the flash drive if you want to start fresh on the tune. this ecu was upgraded to sequential injection which is needed for 60 lb or larger inj's. i ran this for a while then stepped up to the new xs for seq ignition as well as internal sd card for datalogging w/o laptop attached. included are 4 spare jumpers as well as a pic of the expansion port pins for sequential inj wiring as well as ls2 coils and tach output for after market tach. all works well, as pictured $600...... any questions 402....641.....4625
