Post by 85rturbo on Feb 23, 2018 14:18:26 GMT -5
Is the sn95 5.0 throttle body a direct bolt on for the svo? Ive heard about needing an adapter but i havent found anything for sure online yet. Any help would be appreciated. Thanks
luxy72
Boosted Newbie
Post by luxy72 on Feb 24, 2018 8:02:34 GMT -5
You will need an adapter. Bigrmotorsports sells them. Also the 95 GT throttle body is 65mm. So you will need to open up the stock opening on the intake.
Post by Stinger on Feb 24, 2018 12:43:56 GMT -5
While in adapter makes it a bolt on deal they aren't absolutely necessary. The other option is to slot the holes in the throttle body so you can bolt it onto the 2.3 intake. then you also have to remove the throttle cable bracket back one hole so it lines up properly.
