Post by apagnozzi20 on Mar 9, 2018 7:52:02 GMT -5
Almost done doing the 2.3 turbo swap in my 89 Mustang, and the 2.3t is from a 87 Merkur. Now with the Air charge temp sensor (ACT Sensor), the Merkur never had one and there is not a spot on the lower intake manifold for one to thread in. Now my question is, can I drill and tap into my intake plenum for the ACT sensor or is it necessary to find a manifold that has the spot for the sensor built in for it. Thanks in advanced!
~Anthony
Post by Stinger on Mar 9, 2018 8:26:34 GMT -5
The ECU doesn't know how you installed the sensor so you can drill and tap if you want. Putting it in a spot less prone to heat soak is even better...Post intercooler tubing not above engine for example.
Post by apagnozzi20 on Mar 9, 2018 10:00:23 GMT -5
Okay awesome, that is what I figured but just wanted to make sure before I did anything. Thanks so much!
