Post by irsmart21 on Mar 30, 2018 13:26:59 GMT -5
I think this is a good place to post this. If not, can you move this, Stinger?
I have looked across the forum for a discussion of this and could not find anything.
First, I know a gutted upper is not good without the lower being ported in some way. I am getting ready to put a 60mm TB on my car and have to open the flange to match the adapter. I was all but ready to try my hand at gutting my upper myself, but upon researching the best process, I found conflicting reports on other sites with some experience a loss of lower-end power with gutting. All I have ever read is that gutting is the way to go.
It is my understanding that the porting and gutting can be kind of pointless if you do not run a larger than stock TB, being that the air volume is ultimately restricted by the 50mm TB. I did some math and I am hypothesizing that as long as the collective volume of the runners matched the area of the TB, should that not be enough to meet the air supply that is has increased from the TB upgrade.
If the diameter of the individual runners match the above measurements based on the TB size on the car, would that not be enough to at least feel the full benefit of the larger TB and there to effectively not be a bottleneck at the intake? (assuming a fully ported head)
If this is the case, other than the ease of just stripping all of the material out to get max flow, what benefit is there to gutting the upper? I know that I cannot effectively port my upper under my shade tree, but i do not want to gut it if it is going to have an adverse effect on the bottom end/around-town performance.
Just trying to understand it all. Thanks for reading and any replies!
Happy Easter y'all!
TB Size (mm) | TB Dia (In) | TB Radius (In) | TB Area (In2) | Req. Indv. Runner Area (In2) | Req. Indv. Runner Dia (In) |
50 | 1.96 | 0.98 | 3.02 | 0.75 | 0.98 |
60 | 2.36 | 1.18 | 4.37 | 1.09 | 1.18 |
65 | 2.55 | 1.275 | 5.11 | 1.277 | 1.275 |
70 | 2.75 | 1.375 | 5.94 | 1.485 | 1.375 |
Happy Easter y'all!
