boost1
Post by boost1 on May 8, 2018 9:59:19 GMT -5
hi guys just got my svo motor back in car got some upgrades. it sucks engine oil into upper intake and into inner cooler under boost any help plseas.
Post by Stinger on May 8, 2018 10:41:53 GMT -5
How is the PCV system hooked up?
boost1
Post by boost1 on May 8, 2018 11:03:17 GMT -5
stock pcv system running a aftermarket exshaust mainifold stinger 3 inch exshaust kit ported upper intake stock t3 turbo. i read about the catch can idea think it would help. runs graet just oil prob under boost.
Post by Stinger on May 8, 2018 11:06:43 GMT -5
Well, if the oil is in the compressor housing then it's either coming from the turbo oil seal, or from the PCV system which connects to the turbo inlet.
boost1
Post by boost1 on May 8, 2018 11:12:58 GMT -5
turbo was just rebuilt . you drive it runs performs great engine oil in in intake and vam under boost lower end rebuilt last year clyniderhead done this year.
boost1
Post by boost1 on May 8, 2018 11:14:18 GMT -5
do i install catch can?
Post by Stinger on May 8, 2018 11:16:24 GMT -5
You can if you'd like to. Its purpose is to prevent problems like this.
boost1
Post by boost1 on May 8, 2018 11:40:02 GMT -5
im still new to the turbo cars, i have the info on how you did yours does the can need a iinch outlet. where did you get all the fittings.
Post by Stinger on May 8, 2018 11:41:00 GMT -5
All of that information is in the catch can thread, including part numbers and why hose/inlet size matters.
boost1
Post by boost1 on May 8, 2018 11:41:04 GMT -5
some people say to much crank presurre under boost is this possible.
Post by Stinger on May 8, 2018 11:42:31 GMT -5
The catch can is for relieving crankcase pressure which stops the engine from blowing oil out of other places (dipstick, oil cap, PCV, front or rear main seals).
boost1
Post by boost1 on May 8, 2018 11:59:11 GMT -5
thanks for great info. i will order a moroso 85475 today. after i get it done ill send some feed back.
boost1
Post by boost1 on May 8, 2018 12:00:19 GMT -5
just to let you know your 3 inch exshaust kit is awesome my svo never sounded so awesome.
boost1
Post by boost1 on May 8, 2018 13:12:17 GMT -5
hi one more thing in your catch can fourm where did you get the other fitting that the hose goes on.
Post by Stinger on May 8, 2018 16:25:45 GMT -5
What other fitting? The part number and google search results for the big 1" fitting are in the first post of the catch can thread.
