Post by flatnasty on May 8, 2018 13:03:30 GMT -5
When using a aftermarket Air / fuel gauge with a Pimp Ecu can the analog out wire from the gauge be hooked directly to pin 29 if the Ecu O2 sensor signal wire and the the rest of the O2 wires from the Ecu ( power and case ground ) be left unhooked from the Ecu?
Post by Stinger on May 8, 2018 16:24:39 GMT -5
Yes, if those other wires are connected to their proper ground and power connections.
Post by flatnasty on May 9, 2018 10:13:05 GMT -5
What would be the proper connections for the other wires? The gauge connects to the O2 sensor. My question is what about the ground out of the ECU?
Post by Stinger on May 9, 2018 13:09:54 GMT -5
Do you have your Innovate install instructions? If not, it's available on their website. It tells you where to connect each wire. Stock o2 sensor connector has power, ground, and signal wires right there ready to be connected to. That's why startup guide says to use them.
