xsaylr
Post by xsaylr on Jun 6, 2018 13:14:16 GMT -5
I apologize if this has been covered, but i wasn't able to find it in a search. Will the standard 86-93 fuel pump bracket fit OK in an early '84 SVO? I have a Walbro 255 out of an '89 GT, but not the bracket. Or does the Walbro directly fit in the existing SVO bracket? Not a fan of playing in gasoline, so i'd rather have all parts on hand when the time comes, thanks
Post by Stinger on Jun 6, 2018 19:37:38 GMT -5
You need an in-tank bracket for an in-tank pump. GT bracket will work. Look up wiring because there is a resistor that has to be removed to give the pump full voltage.
