Post by pinto148 on Jun 9, 2018 22:59:10 GMT -5
where the hose attaches to the stock throttle body, I have a leak. Cannot tighten the hose enough and after i tighten it it changes the shape and will not seal. I made a boost leak detector and 3 lbs hear the hissing of leaking air. Ran a lot of black tape and the hose fit a little tighter but still leaks. Any suggestions? Thinking of trying a different throttle body. A Sn95?
Post by Stinger on Jun 9, 2018 23:42:45 GMT -5
Moving the clamp closer to the "lip" on the throttle body will often fix the issue. Is the clamp bolt bottoming out?
Post by pinto148 on Jun 10, 2018 7:43:21 GMT -5
had that issue, and bought the next size smaller clamp from your store. brother suggested jb weld and build it up to match the lip
