Post by perri2300 on Dec 12, 2018 15:18:57 GMT -5
I recently installed a 2.3T in my 91 Miata, the stock location of the oil filter would not fit because the steering shaft was in the way; therefore, I installed a remote oil cooler and oil filter relocation kit. I am trying to figure out the routing for my coolant lines. I will not be using the heater core, so I want to use the two inlets on the bottom of the intake from the 85 svo. this is what I think the routing should be:
Line one: water pump to the bottom of the intake. Line two: Thermostat housing to the turbo and the other port in the bottom of the intake. Line three: from turbo to the block.
Will these routes work? Thank you.
Post by perri2300 on Dec 12, 2018 15:30:27 GMT -5
I have the lower intake that comes on the 85 svo.
Post by Stinger on Dec 12, 2018 16:35:02 GMT -5
Post by perri2300 on Dec 12, 2018 22:00:01 GMT -5
Thank you, this helps a bunch. Instead of the lines going to the oil cooler behind the filter, I am just going to route the two lines to the intake.
