Post by redben10 on Dec 27, 2018 7:09:05 GMT -5
Hey guys! I’ve had a turbo 351w setup for a couple months now. Long story short I cracked a radiator and blew a HG. Coolant in my oil wrecked my turbo unfortunately... so I’m looking for a new one! Any opinions on what would be good for my setup? T4 turbo. It’s a street car, mostly roll racing. Stock cam 351w E85 Edelbrock single plane intake 80mm TB 80lb fuel injectors Standalone EMS
Post by Stinger on Dec 27, 2018 12:38:48 GMT -5
Do you have any complaints with the last turbo? What exactly was it?
Post by redben10 on Dec 27, 2018 12:45:49 GMT -5
Do you have any complaints with the last turbo? What exactly was it? It was a 70mm unit that came with the ON3 kit. From what I’ve seen they fall short on higher HP stuff and my wastegate duty cycle is about 80% Almost maxed out at 10psi. As far as complaints go i don’t have any, but i was looking for something to support 6-700hp
Post by Stinger on Dec 27, 2018 13:30:10 GMT -5
Well, the Borg Warner EFR's are the top dogs in turbos right now so if you're willing to spend the $$$, that's where I'd go. They have a matchbot online that tells you which one is the best fit.
