Post by RacingJake on Jan 5, 2019 18:39:28 GMT -5
Attachment DeletedBeen running a Pimpx in my 1987 Thunderbird 2.3 turbo coupe for a few months which was pretty easy to install and figure it out. The All in One Gauge is a whole other story, it will power up but shows no data from the Pimpx. I have the expansion cable hooked up and ECU Can ID is 0 and can master enable is on. All in one gauge Brown wire is hooked up to Can bus H and Purple wire is hooked up to Can bus L I'm wondering if the expansion cable is hooked up to the correct pins in the Pimpx ? Thanks Jake
Post by Stinger on Jan 5, 2019 20:10:23 GMT -5
The wires are in expansion 28 and 27 as shown in the pic. That matches the startup guide. I can't confirm the CAN colors as I can't remember off the top of the my head color is which but you can do that easily. CAN H is supposed to be pin 27 (yellow stripe in your pic).
Post by RacingJake on Jan 6, 2019 12:02:26 GMT -5
Everything is hooked up right and still not working. Now I'm having a serial connection failure that says controller unable to read all pages then Tuner Studio goes off line. Maybe something happen when I was checking the SPR1 & SPR2 to JS6 & JS8 can wires as per Prefect Tuning instructions front page.
Post by Stinger on Jan 6, 2019 12:49:10 GMT -5
I'd suggest contacting Perfect Tuning as they've been able to quickly resolve any issues people have had.
Post by RacingJake on Jan 9, 2019 17:32:17 GMT -5
Thanks Shannon
I got an email back and once I'd enable 29 bits megasquirt the gauge came alive !
PS any word on fuel pumps with kits ?
Thanks again Jake
sanchepd
Boosting 15 psi
347 boosted
Post by sanchepd on Jun 6, 2019 18:17:35 GMT -5
Jake,
what all did you do to get you gauge to work? I have a PIMPxs I am trying to get to work and I even enable 29 bits megasquirt and it still dose not work, gauge turns on but dose not show anything from my ecu.
