Post by RacingJake on Feb 2, 2019 16:37:40 GMT -5
I really like the All in One Gauge and would like it to show injectors duty cycles if possible.
There is one screen that's shows high and low readings and that would be great for that.
So is there a way to set that up ?
Thanks
Jake
Post by Stinger on Feb 2, 2019 23:25:33 GMT -5
It's configurable so if you use the web based configurator but duty cycle is a calculated field based on injector pulse width so it may not be displayable. You'll be best off asking Perfect Tuning for help if you can't figure it out.
With that said, you only need to see the max/peak and you really only need to see it once (like in a datalog) as once you see where you're at, it won't change unless you turn up the boost higher or something. It's not really something I view as data I need to see all the time like AFR or MAP or temp.
Post by RacingJake on Feb 3, 2019 15:50:23 GMT -5
That's good news, thanks for pointing me in the right direction.
Jake
