Post by turborockkrawler on Mar 7, 2019 15:28:28 GMT -5
do I need a vss?
3 pink wires for fuel pump?
cant find were tfi start goes
do I cut the o2 sensor plug and adapt to the wide band 02 plug
red and white wire ecm iab?
redclay color plug 4 wire?
whats the big hole in driver side oil pan sensor?
were do I connect turbo feed
thank you for all the help
Post by Stinger on Mar 8, 2019 0:58:19 GMT -5
You have the directions right? www.stinger-performance.com/MG65.pdfVSS is only needed for speed based features (traction control, launch control, boost by gear, etc.). Yes to the o2 stuff, it's covered in the startup guide how to do it without cutting the harness. Don't know what an IAB is? Diagram on page 2 shows harness layout and what each connector does. Without a pic I have no idea. Oil level sensor. Oil line instructions are linked in the site listing where you bought the line: stinger-performance.proboards.com/thread/131/install-oil-line
Post by turborockkrawler on Mar 8, 2019 15:08:11 GMT -5
I will email you a picture thank you
