Post by alxxpress on Apr 17, 2019 22:03:43 GMT -5
I recently replaced the wiring harness on this car. Everything test fine but the coils. I replaced the TFI module, ran the coil outputs, cranked the motor achieving spark with the new TFI. I connected all the spark plug cables, cranked the car, no spark. I am only running one set of coils on the car also. Are AZ TFI modules do crappy? I'm sure a motorcraft unit is better but is this A common issue in 2.3 cars. Any suggestions with this thing would be great. I've replaced the coil and even installed a new PiMPxs to test. Thanks.
Post by Stinger on Apr 17, 2019 23:03:39 GMT -5
You replaced the harness with another stock dual plug harness or something else?
Was this a previously running setup or a new build?
With PiMPxs test did you configure it for DIS as far as jumpers and software settings are concerned?
Post by alxxpress on Apr 18, 2019 9:52:59 GMT -5
I did configure the xs for DIS, use a correct harness for the car as a replacement. This car did run before A small fire. Might you have a pin out for the duel plug module?
Post by Stinger on Apr 18, 2019 13:24:50 GMT -5
Post by alxxpress on Jun 14, 2019 7:39:19 GMT -5
TFI Module fixed it, thanks for the info.
