Post by turborockkrawler on Jul 12, 2019 18:13:05 GMT -5
Looking to do meth injection to lower intake temps. Looking at snow performance 2.5 which one do you run In rock crawler we don't use intercooler because of packaging, and slow crawling no air flow
Post by Stinger on Jul 13, 2019 1:25:07 GMT -5
Are you wanting a self-contained kit or one that the ECU controls?
Post by maverick on Sept 13, 2019 20:37:22 GMT -5
Im intrested in a pimpxs controlled system. Which setup would you recommend?
Post by Stinger on Sept 13, 2019 21:53:36 GMT -5
Depends how you want the ECU to control it. If you just want to trigger the system to turn on then they are all fine. If you want the ECU to replace the controller then you need to get one of the "base" kits that doesn't have a variable flow controller and then use the ECU for that function using a PWM output and a solid state relay.
Post by maverick on Sept 14, 2019 12:39:14 GMT -5
Is there a best one for using the ecu pwm to control the meth injection? Or just any of the base kits?
Post by Stinger on Sept 14, 2019 13:39:03 GMT -5
Any of the kits that don't have a controller (and therefore are cheaper) are fine. They all have their pros/cons and some companies don't offer a base kit without controller. They all use the same type of pump, lines are lines, nozzles may vary a bit so pick your favorite.
