Post by kendawg73 on Dec 17, 2019 8:35:39 GMT -5
Hi, I'm hoping to be ordering a PimpXS for my '90 GT in the next month. have a couple ?'s
1. do all the stock gauges still work? (fuel gauge, temp, oil, ect) 2. I know all the emissions stuff is 86'ed... but what about the Purge canister? Anyway to still retain that? if not, what is done about that?
Post by Stinger on Dec 17, 2019 10:39:58 GMT -5
1) Yes 2) It's not retained by default but it can be configured to do so.
Post by kendawg73 on Dec 17, 2019 13:13:35 GMT -5
1) Yes 2) It's not retained by default but it can be configured to do so. Great... I would like to at least keep the purge canister to keep the tank from venting and smelling gas all the time... so how hard would this be to add in? also... the expansion harness you sell (the one already wired think it was 79.xx) to plug into the expansion port... how many add on's can you do with that? 1 wire for each thing? at first I'm thinking of added sensor on the fuel rail for FP, and who knows what else down the road.
Post by Stinger on Dec 17, 2019 14:47:29 GMT -5
You just move the purge wire/pin to a programmable output and configure that output to do what you want it to do.
Some of the expansion wires are universal in function, some are more specific (power, ground, etc.). There are some "universal" ones in the EEC connector as well (like I mentioned using for the purge above). If you're only doing a couple extra things it can be done through the EEC connector.
