Post by 79couriersvo on Jan 3, 2020 10:40:39 GMT -5
Hey guys, I'm new the the forum. I have a Ford courier that I swapped an 87 turbo coupe motor into, when i got the motor, it didn't come with a computer or wiring, so I invested in a megasquirt ms3x and made a harness, deleted the distributor, using ls1 coils, I modified the oil pump/distributor drive wheel to have a single tooth, and have a 36-1 wheel off a ranger so I can run fully sequential. My issue has been starting totally from scratch without a tune to work from, finding every parameter and setting to adjust. The only msq I could find was on the diyautotune site, and it's for ms2, which isnt compatible with my hardware. Does anyone have an msq for ms3/x? Even if its base ms3 it would still fill in alot of the blanks. I know I still have alot of leg work to do either way, but it would really help me to have some place to start from. Thanks in advance.
Post by Stinger on Jan 3, 2020 13:20:02 GMT -5
Sounds like an interesting project. While I understand starting from scratch is rather daunting, this is one of the competitive advantages we have with our PiMPxs ECU's (and one of the disadvantages of the DIY method; sorting through all of the documentation to find what is relevant to your hardware & combo) so it's not something we can give away.
