Post by ibdalovely1 on Jan 8, 2020 19:18:18 GMT -5
I'm looking for a Ron Francis harness for not 500 bux for a 2.3 or some one to set up mine as a stand alone harness it's from a 1988 ranger
Post by Stinger on Jan 12, 2020 23:08:41 GMT -5
There are a bunch of different RF harness part numbers for 2.3's so you'd likely be best off to include what part number you're after.
As for the Ranger harness, more details about what you're trying to accomplish with it would help (use it in what vehicle with what engine and what ECU).
Post by ibdalovely1 on Jan 13, 2020 1:15:39 GMT -5
Well I've had a issue with the truck side of the harness and the engine side in different occasions I'm just tired of chasing issues in-between two last time it decided it just wanted to keep the starter engaged and it just gunned it's self to like 3k rpm melted the wires to the starter and the ground was smoking as I was banging on the battery to get the terminals off and the starter is junk with all that it's just a dead short now so I have the engine harness and ecu all pulled and the harness stripped if I had a exact diagram of whear everything went I could do it myself i can get the numbers on the ecu if that wout help any
Post by Stinger on Jan 13, 2020 22:39:09 GMT -5
OK, well that does sound like a good reason to pull the harness and consider replacing it, however you didn't answer the questions I asked above about part numbers, what engine, what ECU, etc.
Post by ibdalovely1 on Jan 14, 2020 10:30:39 GMT -5
I'm sorry was at work othe last reply It's a 1988 ford ranger extended cab 2.3 not the 8 plug head it's just the standard engine distributor with tfi fuel injected the ecu has several numbers I'm not sure exactly which ones you need so I put a pic I've got a couple different schematics of the 2.3 harness and have kinda figured out where I need grounds and voltage I'm just unsure but I know I will I need a resister to the coil because it's built into the truck side of the harness and theirs what I think is a diode that confuses me on it's purpose
Post by Stinger on Jan 14, 2020 18:05:43 GMT -5
So it's all stock Ford stuff for an 88 Ranger with no plans for anything else in terms of mods, swaps, etc?
Post by ibdalovely1 on Jan 14, 2020 19:10:44 GMT -5
So it's all stock Ford stuff for an 88 Ranger with no plans for anything else in terms of mods, swaps, etc? It's stock for now maybe a turbo some day but stock
