Egr delete
Feb 28, 2020 23:59:52 GMT -5
via mobile
Post by Hueneme805 on Feb 28, 2020 23:59:52 GMT -5
Has any one done a egr delete on a 1987 turbo coupe driving it and with out any check engine light and no mods to ecu? Or is that not posible with out tuning in out.
Post by Stinger on Feb 29, 2020 0:03:01 GMT -5
Yes, it's pretty standard. It will throw a code but it won't make the check engine light come on. With that said, it won't really change anything unless it's malfunctioning. It's disabled under boost anyway.
Post by Hueneme805 on Feb 29, 2020 0:09:45 GMT -5
So car will run fine as long as everything is plugged good for no leaks at vacuum tree/ exhaust manifold/ upper intake. It’s for the rotation of upper intake why I’m concerned. Tight fit so I’d rather delete only if car will not change drivability.
Post by Stinger on Feb 29, 2020 0:59:16 GMT -5
Yes
Post by Hueneme805 on Feb 29, 2020 1:06:43 GMT -5
Ok I’m gonna delete egr and use stock ecu and just rotate uppper intake.
