Post by perri2300 on Mar 13, 2020 13:59:48 GMT -5
I have a Magnafuel FPR that needs a boost reference. Do I just get the boost reference from any location before the throttle body? are two filter generally used in-line with the fuel system? If so, What micron and size you anyone recommend the filters be? I am using -6AN line for the whole fuel system and I would like to use a fuel filter from magnafuel or something similar.
Post by Stinger on Mar 13, 2020 23:05:43 GMT -5
The stock FPR hose source location is in the upper intake behind the throttle body, right near where the regulator would sit on the rail. That's about as good of a source as there is. Otherwise it can come from any source that's behind the throttle body (behind meaning it's a location air goes AFTER it passes through the throttle body). Vacuum tree for example.
The fuel pump manufacturer typically has a micron suggestion for use with their pumps, I'd start there. There is normally a fine particulate filter near the pump and a larger particulate one near the tank (or in the tank depending on pump type).
