tyler
Post by tyler on Mar 24, 2020 20:25:49 GMT -5
How often is it recommended to change the timing belt? Thank you
Post by Stinger on Mar 24, 2020 21:02:49 GMT -5
If you've got a stock cam then you can run them a lot longer as it's a non-interference engine so if it breaks it doesn't damage anything. For big cams and stiff valves there are a lot of variables (miles vs sitting outside in the weather drying out, etc.) but typically they will start to crack around the teeth way before they are ready to fail. I'd guess the stock replacement schedule was something like 100k miles but I don't know for sure.
