xsaylr
Post by xsaylr on Apr 5, 2020 20:34:13 GMT -5
What's up fellas, I installed a catchcan a while back per forum instructions, and it's worked great. However the valve cover breather fell apart, so I'm looking for a replacement. This 1 never fit too well, it tended to lean quite a bit and almost fall off. Do you have any recommendations?
Post by Stinger on Apr 5, 2020 21:56:25 GMT -5
There are multiple valve cover breather versions that came with 2.3's so you need the one that matches your valve cover (1/4" hole, 3/16" pipe, rubber grommet, etc. are all stock valve cover breather connection types).
