Post by leroy420b on Apr 28, 2020 22:52:54 GMT -5
My problem like the title says is that my ignition seems to be randomly cutting out. When this happens if i stay in the throttle it loads up and boom a big back fire out the tail pipe when it kicks back in. That makes me believe that the injectors are still firing. The tach also drops to zero and or jumps all over the place. I have swapped out both the dizzy and the coil with known good ones and no change. I also replaced the ignition switch. It seems to happen more when the car is cold. Here is a video of it happening while driving. HERE One when trying to start it cold. AND HERE I have a datalog of it happening multiple times I am just not sure how to share it? Any help is appreciated!
Post by Stinger on Apr 28, 2020 23:55:32 GMT -5
If you post in the PiMP section then you can upload the log. I'd suggest doing that.
