Post by choklos88 on May 3, 2020 13:17:27 GMT -5
setting up my pimpx on and got a question. I have greentop injectors which should be 30lbs. Are they low or high empadance. Swap came from a tbird . What type of Ignition do i have bc there are 4 types to choose from. TFI,, DIS,, EDIS, CDI BOX WITH TFI.thanks in advance.
Post by Stinger on May 3, 2020 13:56:29 GMT -5
Stock 2.3T injectors are low impedance.
TFI ignition.
Post by choklos88 on May 4, 2020 21:26:35 GMT -5
thanks stinger. Heres another question i navigated through the instructions for.the ecu. Where in your website do i find the characteristics of the injectors. Deadtime, etc.
Post by Stinger on May 4, 2020 21:51:47 GMT -5
You just use the injector dead time suggested in the startup guide for stock injectors. Leave everything else injector related as supplied.
You're going to be out of injector immediately btw. Brown tops are maxed out with minimal mods, green tops are 15% smaller than that.
Post by choklos88 on May 5, 2020 16:21:51 GMT -5
Thanks. The injectors are next in my list.
