tyler
Post by tyler on May 4, 2020 12:30:08 GMT -5
Are there any major differences between d port and o port turbo heads?
Post by Stinger on May 4, 2020 12:47:10 GMT -5
Not other than the shape of the ports and one of the intake manifold mounting holes is in the wrong spot if using a square style intake (so drill & tap the new location and you're good to go). Oval port heads can be used with D port intake manifolds without porting.
