Post by xr2300 on May 17, 2020 14:05:39 GMT -5
When I bought my car the boost control solenoid was removed and a manual boost controller was installed. I’m looking down the road and planning to install a electronic boost controller with my pimp unit. I’ll need to wire in a new plug for the boost controller. Im wondering if one of these plugs went to the stock boost control solenoid? photos.app.goo.gl/S5xwEd3RoNnYHrs69
Post by Stinger on May 17, 2020 16:24:09 GMT -5
It's that round connector front and center in the pic. To use our solenoid with the PiMP, you cut that connector off and replace it with the pigtail we offer with our solenoid.
Post by xr2300 on May 17, 2020 16:55:17 GMT -5
Thanks. I was wondering about the round connector, but it has 3 wires to it. A EV1 type connector has two wires. Is one of the wires not used?
Post by Stinger on May 17, 2020 19:05:37 GMT -5
Yeah, it should be 2 wire. It's also a male connector though so I don't see it in the pic. The factory solenoid & connector looks like this which you can compare to your wiring: www.ebay.com/i/202557155820
Post by xr2300 on May 17, 2020 19:26:57 GMT -5
I’ll dig around the wiring to see if I can see something similar. I know there is not a lot of wires around this area but should it come off the same wiring bundle is the BAP sensor?
Post by Stinger on May 17, 2020 19:40:00 GMT -5
It's on the passenger side wiring bundle. I'd check on both sides of the strut tower as you never know what someone before you did to it.
