Post by firewheel56 on May 19, 2020 22:14:15 GMT -5
is it ok to put in one of the magnaflow cat that you sell ? motor is a 2.3T w /pimp i would like to try to make the exhast quiter . right now i have two magnaflow mufflers. and if ok to run and not loose to much power then i will go with the new spun-cat if the outside is not to hot . or a muffler that you sell. THANK YOU
Post by Stinger on May 19, 2020 22:44:10 GMT -5
It won't hurt power much but it will get hot. That's how cat's work is getting hot enough to make chemical property changes happen to convert "bad stuff" into "not so bad stuff". The conventional (not spun) cat's have a sort of integral shield that protects things from heat a bit more than the spun version.
Using a third muffler (resonator) depends on how much clearance you have as a 3" ID resonator is like 5-6" OD and 14-20" long (sort of like a glasspack type muffler but without the flow restriction) but they will quiet it down significantly.
Post by firewheel56 on May 20, 2020 0:08:25 GMT -5
THANKS SHANNON i will try to put in a resonator . if i get one in i will give a update good or bad.
Post by Stinger on May 20, 2020 1:27:22 GMT -5
Magnaflow # 14419
Post by firewheel56 on May 20, 2020 23:52:34 GMT -5
SHANNON i do have the #14419 in right now and a oval one so i am hopeing i can try to put the resonator in and try it. THANK YOU.
Post by Stinger on May 21, 2020 0:34:31 GMT -5
In that case, mufflers aren't the problem. What sort of tailpipe/exhaust exit arrangement do you have? Full tailpipe that exits out the back or side or something that dumps under the car?
Post by firewheel56 on May 21, 2020 20:25:37 GMT -5
SHANNON the sound right now would be fine for most people. BUT my floors are wood and the car is a 29 modelA 4door . get alot of noise in the car when i had just a stock muffler it was quiet. then i put in your 3in. down pipe to the 14419 13in pipe to a oval magnaflow to over rearend than a 45% then out to the side of the car maybe 1in. past body/fender line,, THANK YOU LANDY
Post by Stinger on May 21, 2020 21:45:53 GMT -5
OK, was just making sure it wasn't dumped under the car as that adds a LOT of sound inside even though it's not louder outside.
Post by firewheel56 on May 31, 2020 10:53:51 GMT -5
UPDATE: I took out the 2 magnaflow mufflers and put in a big muffler in and now the car is real quite . maybe the spool time is a little slower but that is ok i took the car in the hills and it run fine . os iam happy if i give up alittle power to be able to drive for 6 hours then that is ok . THANKS
Post by firewheel56 on Aug 29, 2020 20:48:27 GMT -5
UPDATE i had to much power loss so i took at the muffler and put in a longer magnaflow then i had and put in a resonator you could look thru and it so about the same for noise that i had with the muffler. i got back the spool time and power, i feel i do not care about spool time as much as i do about power running down the road. i do know how to make it quieter and that is to put a freeflow cat in my car i can not because my floors are made of wood and will burn .so this is the update to my muffler install. good or bad i always try to update . most of the time my road test are on the same roads and are about 150 miles . THANK YOU
Post by Stinger on Aug 29, 2020 21:32:30 GMT -5
I suspect you'd be OK with a cat if you put a heat shield between the cat and the wooden floor.
Post by firewheel56 on Aug 29, 2020 21:55:15 GMT -5
I may try a cat that you sell down the road THANKS
Post by Stinger on Aug 29, 2020 22:07:48 GMT -5
Our "normal" (not spun) cats have a small built-in shield on them.
