Post by frankglz91 on May 27, 2020 10:18:49 GMT -5
I am searching for a timing table for a turbo coupe swap. It has a 2.3L with a Precision Turbo - was bought complete with limited info. I've searched for a timing table on here but have not found. I would appreciate some help. Car is seeing 22psi of boost right now and I have it turned down. Trying to make adjustments but stay somewhat conservative.
Thanks for your help!
Post by Stinger on May 27, 2020 10:30:39 GMT -5
The base tunes come with a timing table that is somewhat conservative for 93 octane. The startup guide says what to do to adjust it for 91 octane. There is also a picture of a timing table in the PiMP "how to tune" thread.
Post by frankglz91 on May 27, 2020 10:42:54 GMT -5
The base tunes come with a timing table that is somewhat conservative for 93 octane. The startup guide says what to do to adjust it for 91 octane. There is also a picture of a timing table in the PiMP "how to tune" thread. Thank you. I was able to locate the attached timing table. So this one is for the 2.3L? I unfortunately don't have the base tune that came with this car. Thanks again bud. Attachment Deleted
Post by Stinger on May 27, 2020 11:17:51 GMT -5
It is a map from a 2.3T car. It is not the one provided in any of our base tunes.
Post by frankglz91 on May 27, 2020 12:08:09 GMT -5
It is a map from a 2.3T car. It is not the one provided in any of our base tunes. Okay that works. It gives me an idea. I tune a lot of V8 cars and wanted to get an idea before putting more timing into the 2.3L Turbo. Anyway to share the base timing table you provide for the 2.3s? This customer does not have the USB with the original tune. It's an original PIMP ecu and is working great!
Post by Stinger on May 27, 2020 14:21:13 GMT -5
Yes, they are included in any of the accessory packs on our site that are intended for people who buy used ECU's and don't get everything the ECU originally came with, or lost their original USB, jumpers, etc. It's common for people to sell the ECU's and not include the stuff needed to use them, or to either lose the USB/jumpers, or throw them away assuming they don't need it.
