Post by Stinger on Feb 5, 2010 13:51:37 GMT -5
The Stinger "Center Mount" Header is finally back in stock. I plan to keep them in stock for quite a while now. Worst case scenario would be a 7-10 day delay on orders if I can't quite keep up with the sales.
There have been some upgrades made to the header, notably additional bracing on the wastegate tube and stronger welds throughout. The inlet into the header flange is now smoother/larger and the collector area is smoother and less restrictive now as well.
don33
Post by don33 on Feb 19, 2012 20:39:30 GMT -5
stinger could you comment on the durability of the improoved version of of your header. I would think this should be a good upgrade.
Post by Stinger on Feb 20, 2012 0:44:16 GMT -5
It seems to have increased durability quite a bit. It's certainly no E6 as far as durability is concerned (no header is) but it's improved.
