Post by Hueneme805 on Jul 5, 2020 1:41:22 GMT -5
Hello group, what is the correct fluid to use for rack n pinion. Is it power steering fluid or atf oil.? Also what is the correct way to remove air from system(tires on ground or slightly lifted and with key on or vehicle completely on. With wheel lock left to right?)
Post by Stinger on Jul 5, 2020 2:42:07 GMT -5
ATF, dexron w/mercon
I'm not positive on the air. I think you just make sure it's full and turn it back and forth while running. Lifting the tires just prevents you from wearing the tires out turning back and forth.
