tyler
Fuel pump
Jul 10, 2020 15:59:47 GMT -5
via mobile
Post by tyler on Jul 10, 2020 15:59:47 GMT -5
Hello. Just tried starting my car the other day (2.3 turbo) and it would not start. I realized that the fuel pump wasnt priming/making the buzzing sound for a few seconds. What i could hear was the integrated relay control module little black blox click Twice and then a single click close to the injector harness plug. Any thoughts? Thank you
Post by Stinger on Jul 10, 2020 20:45:42 GMT -5
The IRCM is just a box with relays inside and basically anything that's clicking is also a relay or a solenoid (like injectors).
How low was the battery voltage when you were trying to start it? Had it sat a while or had it ran in the last couple days?
tyler
Fuel pump
Jul 10, 2020 21:28:47 GMT -5
via mobile
Post by tyler on Jul 10, 2020 21:28:47 GMT -5
Failed to check my volt gauge..however had plenty of juice to crank it over. I just started it the day before, so two days ago now
Post by Stinger on Jul 10, 2020 21:57:57 GMT -5
So the pump isn't priming (on then off after 5 seconds) but it's also not running constantly?
tyler
Fuel pump
Jul 10, 2020 22:01:46 GMT -5
via mobile
Post by tyler on Jul 10, 2020 22:01:46 GMT -5
It isnt priming, which leads me to think it isnt running at all
tyler
Fuel pump
Jul 10, 2020 22:02:01 GMT -5
via mobile
Post by tyler on Jul 10, 2020 22:02:01 GMT -5
Before this it ran fine
Post by Stinger on Jul 11, 2020 1:02:20 GMT -5
Can you connect to the ECU via your laptop and does it act normally in that regard?
tyler
Fuel pump
Jul 11, 2020 9:10:01 GMT -5
via mobile
Post by tyler on Jul 11, 2020 9:10:01 GMT -5
Yes it all acts normal and i able to connect no problem
tyler
Fuel pump
Jul 11, 2020 9:56:10 GMT -5
via mobile
Post by tyler on Jul 11, 2020 9:56:10 GMT -5
I just put a test light on the inertia switch and got no light. I put the light ground on the tailight stud and poked the test light end through onto the each wire and it didnt light up for either wire
Post by Stinger on Jul 11, 2020 14:28:31 GMT -5
Sound like you need to dig into the inertia switch, grounds, etc.
tyler
Fuel pump
Jul 11, 2020 15:03:06 GMT -5
via mobile
Post by tyler on Jul 11, 2020 15:03:06 GMT -5
Sounds good. Are there any writeups or posts about this you know off the top of your head?
Post by Stinger on Jul 11, 2020 15:39:23 GMT -5
I'm sure there is one out there somewhere but I don't think there is anything about inertia here.
tyler
Post by tyler on Jul 11, 2020 16:24:53 GMT -5
Thank you!
