93 na
Dec 5, 2008 15:48:54 GMT -5
Post by Stinger on Dec 5, 2008 15:48:54 GMT -5
No, they don't have the definition files required for the 2.3 ecu's. You can have all the stuff required to chip a 2.3 turbo ecu for ~ $150 which is way cheaper than a "one time shot" shop tuned chip anyway.
93 na
Dec 5, 2008 19:31:21 GMT -5
Post by 93redgt on Dec 5, 2008 19:31:21 GMT -5
not trying to keep being a pain, what do you mean dont have the defintion files,and how do get the stuff required for 150 and what is that stuff
93 na
Dec 5, 2008 21:44:19 GMT -5
Post by Stinger on Dec 5, 2008 21:44:19 GMT -5
They have to know how the ecu works at a programming level and then have the equipment required to make the chips. For 5.0's, because they are so common, there are a number of companies that have done the legwork required. For 2.3's, this just isn't the case. If you want to know more about tuning, start a thread in the ecu tuning section. That way it can be preserved for others to find the info in the future.
mac91
93 na
Dec 7, 2008 19:49:55 GMT -5
Post by mac91 on Dec 7, 2008 19:49:55 GMT -5
so can i run a turbo ecu with a chip keep the dis and put a turbo head on the 93? also the forged pistons of course and the larger injectors.
93 na
Dec 8, 2008 0:24:50 GMT -5
Post by Stinger on Dec 8, 2008 0:24:50 GMT -5
Yes.
mac91
93 na
Dec 8, 2008 12:27:35 GMT -5
Post by mac91 on Dec 8, 2008 12:27:35 GMT -5
who does chips for the turbo ecu? is there ne thing special i have to do to run the dis.
93 na
Dec 8, 2008 15:37:08 GMT -5
Post by Stinger on Dec 8, 2008 15:37:08 GMT -5
The chips are a "do it yourself" tuning option. The ecu doesn't know whether you are running a distributor or DIS, the signal is the same. It's just wiring changes. If you want to know more about ecu tuning, start a thread in the ecu tuning section. That way it can be preserved for others to find the info in the future.
mac91
93 na
Dec 9, 2008 19:45:01 GMT -5
Post by mac91 on Dec 9, 2008 19:45:01 GMT -5
would i have to lose the mas bc of the turbo ecu?
93 na
Dec 9, 2008 23:55:17 GMT -5
Post by Stinger on Dec 9, 2008 23:55:17 GMT -5
I "think" I've heard of someone using a full option superchips tuner ($650+) to be able to modify the DIS ecu. If you choose to go this route, you are completely on your own though. I just don't understanding the attachment to the DIS ecu. Why do you want to keep it so badly?
mac91
93 na
Dec 10, 2008 12:26:03 GMT -5
Post by mac91 on Dec 10, 2008 12:26:03 GMT -5
i cant find a turbo motor and trying to figure out a way to boost the car without the doin a complete swap. is there a diff in the turbo block and the 8 plug 93 block?
93 na
Dec 10, 2008 15:34:27 GMT -5
Post by svojohn on Dec 10, 2008 15:34:27 GMT -5
Which eec-iv do you have? D1L1? C1A1?
93 na
Dec 10, 2008 18:52:52 GMT -5
Post by Stinger on Dec 10, 2008 18:52:52 GMT -5
i cant find a turbo motor and trying to figure out a way to boost the car without the doin a complete swap. is there a diff in the turbo block and the 8 plug 93 block? There are some differences but nothing that makes it unable to be turbo'd. Just put some forged pistons in it.
93 na
Dec 10, 2008 19:34:32 GMT -5
Post by 93redgt on Dec 10, 2008 19:34:32 GMT -5
Which eec-iv do you have? D1L1? C1A1? will one of them work? i just think if some one took the time that it would be a better set-up, it would already be mass air and dis no converting. if not im just going to repin and convert to the vam leave dis then for the start im going to put a turbo on my 8 plug see how long till it pops then put the turbo motor in
mac91
93 na
Dec 10, 2008 20:48:46 GMT -5
Post by mac91 on Dec 10, 2008 20:48:46 GMT -5
how much boost with nothing but pistons and 225lph with aero regulator
93 na
Dec 10, 2008 22:44:30 GMT -5
Post by 93redgt on Dec 10, 2008 22:44:30 GMT -5
what will the stock fuel lines support hp wise
