Post by kevinl1058 on Aug 14, 2020 14:23:31 GMT -5
I just purged the line prior with 2 key cycles. Guage is holding pressure at 15Lb. Do I set the fuel pressure with injectors unplugged then reset when running?
Post by kevinl1058 on Aug 14, 2020 14:41:02 GMT -5
Got it set, the set screw was back out quite a bit from the factory. Holding @ 43lbs when keyed on
