guss
Post by guss on Aug 18, 2020 10:56:22 GMT -5
Hi All new guy. I am working a fater son project with my son on his 84 2.3 tubo mustage . It runs great but no history on a few important things. So I said new water pump and timing belt and tensioner . 1 st the new water pump has 3 bolt holes the water pump that came off has 3 bolt holes but also a hole that lines up with hole in block ? So is my New water pump wrong by blocking that hole off???
Post by Stinger on Aug 18, 2020 14:24:53 GMT -5
So both the old and new pump have 3 holes but they are not the same bolt pattern so one of the holes doesn't line up? How far off is it?
guss
Post by guss on Aug 18, 2020 17:26:00 GMT -5
No water pump will bolt up not the issue. My old water pump has a hole next to the top bolt it lines up to hole in block. But my new water pump will bolt up but does not have a hole in it to line up with hole on block a water passage hole about a 1/4 inch hole. I have what is believed to be the original motor In my sons car a 2.3 turbo car not svo. Thanks for any info.
guss
Post by guss on Aug 18, 2020 17:27:13 GMT -5
I need to figure the pictures out as n can load them.
Post by Stinger on Aug 18, 2020 19:24:24 GMT -5
There are only 3 water pump holes on 2.3 blocks:
guss
Post by guss on Aug 18, 2020 21:21:59 GMT -5
OK Figured out pictures so first is old pump
then new pump
both with 3 bolt holes but old pump has a hole that matches the one in the block
see pictures
Post by Stinger on Aug 18, 2020 22:00:05 GMT -5
Upload pictures to a photo host site like imgur.com and post the link to them here, or put them in a cloud backup (icloud, google photos) and then put the "share" link here.
guss
Post by guss on Aug 18, 2020 22:06:58 GMT -5
Post by Stinger on Aug 18, 2020 22:19:04 GMT -5
guss
Post by guss on Aug 18, 2020 22:23:20 GMT -5
<a href="https://imgur.com/OeUcgx5"><img src="https://i.imgur.com/OeUcgx5.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/wczn28U"><img src="https://i.imgur.com/wczn28U.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/P6MDBF6"><img src="https://i.imgur.com/P6MDBF6.jpg" title="source: imgur.com" /></a>
guss
Post by guss on Aug 18, 2020 22:26:35 GMT -5
"share"https://imgur.com/OeUcgx5
guss
Post by guss on Aug 18, 2020 22:29:38 GMT -5
guss
Post by guss on Aug 18, 2020 22:34:26 GMT -5
guss
Post by guss on Aug 18, 2020 22:36:41 GMT -5
guss
Post by guss on Aug 18, 2020 22:38:36 GMT -5
