Post by perri2300 on Sept 7, 2020 1:26:51 GMT -5
I am going to start my car for the first time tomorrow, but I am not sure what I should set the fuel pressure at. I have an adjustable magnafuel FPR. I should mention I should mention I have microsquirt and a walbro 255 installed in the car.
I am also going to prime the oil in the engine by pulling the distributor out, but I cant remember if the shaft needs to turn clockwise or counter-clockwise; it has been a long time since I have done this.
Post by Stinger on Sept 7, 2020 12:57:17 GMT -5
Set it to somewhere between stock (39psi) and the industry standard (43.5psi).
Shaft needs to turn the same way as the distributor turns when running (clockwise).
Post by perri2300 on Sept 7, 2020 16:19:01 GMT -5
Thank you, I am about to prime it now!
