Post by kevinl1058 on Sept 24, 2020 19:40:26 GMT -5
So I just picked up a set of motorcraft wires. Resistance #s varied quite a bit on the 20K scale. 12.3 / 28” 20.2 / 31” 17.2 / 28” 15.1 / 31” Is this an acceptable range or take them back for another set?
Post by Stinger on Sept 24, 2020 21:37:12 GMT -5
They have a lifetime warranty so there is no harm in running them.
Post by kevinl1058 on Sept 24, 2020 21:42:02 GMT -5
What’s an acceptable resistance range? I’m not going to be running High boost (20lbs) tops.. autolite 104 copper plugs gapped to 28 or 30? Thanks
Post by Stinger on Sept 24, 2020 23:20:39 GMT -5
I've never measured a bad set so I don't know definitively. I know they have more resistance than aftermarket stuff but our ignition system seems to be OK with that.
Post by kevinl1058 on Sept 25, 2020 9:55:50 GMT -5
Good to know on the lifetime warranty. I ran duralast wires just for the breakin phase and had come to see that the Retaining clip that retains the wire to the plug had stretched? so the wire wouldn’t even seat securely on the plug.
Post by Stinger on Sept 25, 2020 13:10:01 GMT -5
I assume they are still lifetime, they always used to be but I haven't checked in a few years.
Post by kevinl1058 on Sept 25, 2020 14:47:30 GMT -5
The good old days when products had that lifetime warranty.
