Post by Stinger on Mar 11, 2022 19:58:37 GMT -5
It will be taken care of.
Post by beatrod on Mar 12, 2022 7:40:18 GMT -5
Thank you a super ton stinger!!!!! Your the man!
Post by beatrod on Mar 12, 2022 16:09:06 GMT -5
Also, it says the order was refunded.. The whole order? Like should i place it again for the drain line and the gasket? Or just wait?Sorry, im just anxious to drive this thing😂
Post by Stinger on Mar 13, 2022 11:03:31 GMT -5
It says refunded because we refunded the extra line you ordered.
Post by beatrod on Mar 14, 2022 3:56:10 GMT -5
Gotcha. I was just wanting to be sure. Thank you a tone shannon!! Giant help, you are!
Post by beatrod on Mar 18, 2022 21:44:55 GMT -5
Got the line. Got it on, although i havent been able to go down road and build boost just yet to know for sure that was the only problem im having. Quality was extremely nice though! Im thinking the knockoff header sits the turbo a bit lower than yours though. Once the line gets over by the block it has to run up hill a bit. I wouldnt say its enough to hurt anything by any means! But its good to have for records perhaps. Fitment was still great and once it gets warm it could very well flex into a better position. Thanks again Shannon!
Post by Stinger on Mar 19, 2022 22:07:40 GMT -5
As long as it's a gradual climb and only goes up a 1/2" or so, it won't cause any problems.
Post by beatrod on Mar 22, 2022 4:11:26 GMT -5
Yea it should be fine. Drove fine though. But a new problem has emerged i have to chase down.. Fuse for ecm/tfi/injectors and something else on the ron fransis replacment harness keeps blowing. Like every 20 feet. Got some kind of short. I know you dont make those harnesses, but if a tfi goes out, its normally good or bad right? Because it would run under like 2k but die when you put any load on it. Now the fuse blows as soon as i turn the key. Would that be able to make such a short?
Post by Stinger on Mar 22, 2022 10:01:48 GMT -5
A bad TFI won't blow a fuse.
Post by beatrod on Mar 22, 2022 11:05:12 GMT -5
I didnt think it would but wanted more experienced input. Not sure what its deal is.. Maybe i shouldnt have left the car sitting so long🤷😂
Post by beatrod on Mar 24, 2022 7:24:26 GMT -5
CEL power pin 37 was grounding on dash frame popping ecm fuse on ron frances wire harness. Drove to work, all seems well. Il be getting a tail pipe from you right here soon. DP to the trans crossmember is a bit loud😂
Post by Stinger on Mar 24, 2022 10:08:58 GMT -5
Good to hear you found the issue!
Post by beatrod on Mar 24, 2022 12:26:12 GMT -5
Yea, posting incase someone else has similar problems.
