Post by cjdavid on May 8, 2010 15:22:37 GMT -5
HOW BOUT SOME PICS OF FRONT MOUNTING OF YOUR INTERCOOLERS. I NEED SOME EXAMPLES OF HOW YOU'VE DONE THEM PLEASE.
Post by Stinger on May 8, 2010 18:43:32 GMT -5
It's going to vary depending on the size/shape/design of the intercooler.
Post by cjdavid on May 8, 2010 19:11:49 GMT -5
STINGER, UNDERSTOOD, JUST WANTED TO SOME CREATIVE FABRICATIONS.
Post by Stinger on May 9, 2010 14:56:19 GMT -5
What specifically are you looking to see?
Post by cjdavid on May 10, 2010 5:25:01 GMT -5
Mounting brackets and where they are on the core support. Again, I do realize they will be different as to the configurations of the I/C.
Post by Stinger on May 10, 2010 15:37:24 GMT -5
They typically are in front of the core support and radiator, mounted to the threaded but unused factory holes in the upper core support. Some intercoolers with bottom mounting holes will use holes drilled through the lower core support with bolts to mount it at the bottom.
Post by cjdavid on Jan 7, 2011 18:57:51 GMT -5
I'm wondering how much "trimming" I can do without messing up the strength of the front end. I'm wanting to be able to put the A/C back on the car at some point and need to get the inner-cooler further out past the core.
Post by Stinger on Jan 8, 2011 0:31:50 GMT -5
Most of the strength from a crash standpoint is in the bumper and bumper supports (under the bumper cover).
Post by Matt Culpepper 2300gearjammer on Jan 8, 2011 10:05:20 GMT -5
Post by Matt Culpepper 2300gearjammer on Jan 8, 2011 10:07:23 GMT -5
...also you will need to decide whether you want performance over comfort. Which ever you prefer will be the item that goes out in front. Meaning if you want AC to be really cold it will need to be in the front. You'll also probably need to think about a pusher fan for the AC condenser.
Post by cjdavid on Mar 12, 2011 14:59:36 GMT -5
Matt, My i/c is about 1/3 the size of yours. Inlet and outlet are on the passenger side. I do want to put the a/c back on the car at some point and I'm planning on mounting it in the stock location.
Post by cliffdiver86 on May 25, 2011 11:06:04 GMT -5
Post by seifertjoey on May 20, 2012 15:28:13 GMT -5
is that a VAM in the charge piping on the intake side?always wondered if i could do that?!?!?!?!?!?!!?!?!?!?!?
Post by warwickben on May 20, 2012 18:52:55 GMT -5
Yeah mines not norm
Post by warwickben on May 20, 2012 18:56:46 GMT -5
This shows my brackets on the top going to the bumper. The inter cooler has tabs on the side. I welded a Bolt to each frame rail put a bolt through the tab with skate board bushings above and below the tabs. Or u could use sway bar endlinks bushing . It's the knock off ford cosworth intercooler .
