svslow
Post by svslow on May 20, 2012 20:45:44 GMT -5
My Precision intercooler on the SVO. I made a couple brackets that utilized the bumper support bolts.
Post by warwickben on May 21, 2012 11:29:46 GMT -5
Nice! The trick is use what ever bolt holes u can use when doing a setup and if you can you can buy this tool. It's like a pop rivet gun but the "rivets" are threaded inserts. makes things easy.
Post by seifertjoey on May 21, 2012 23:55:48 GMT -5
if i do put my vam in my charge pipinh which im prolly doin now.is it better to be closer to turbo or trottle body?or does that ven mtter?
Post by warwickben on May 22, 2012 4:49:19 GMT -5
You quoted me, I don't have a vam so I'm not the best to ask. But most of what I seen with maf setups have it after the intercooler and a blowoff and before the tb. My thinking is it sees the denser air after the intercooler and dose not see the air bleed off by the blow off. This is all guess .....
becools
Addicted to boost..
Post by becools on May 23, 2012 8:40:05 GMT -5
Post by warwickben on May 23, 2012 16:06:00 GMT -5
What is that plate type shelf thing it's sitting on?
