Post by 93lxturbo on Jun 10, 2010 17:57:07 GMT -5
ok when i 1st start it up with the ms2 or after it cools off, it will start up for like 5 seconds then it dies it like it haves to warm up before it will idle out.. ones it warms up its fine.
Post by Stinger on Jun 10, 2010 18:19:25 GMT -5
Have you read the megamanual for MS2 about warmup enrichment, cold start enrichment, and afterstart enrichment?
Post by 93lxturbo on Jun 10, 2010 19:30:24 GMT -5
yes i did and i got lost lol, here another one when i turn Launch Control on and then turn the car off it kill the fuel pump and i have to turn Launch Control off for it to be able to start back up
Post by Stinger on Jun 10, 2010 20:59:52 GMT -5
If you got lost, you need to re-read until you understand it. All the answers to how to setup your crank/strart/afterstart/warmup is right there. Checking the coolant temp when it has the issue (what all those tables are at least partially based off of) will give you an idea where it needs adjusted. I guess worse case if you don't understand it, you can just add or remove enrichment in those tables to see which makes it get better. Just remember to save as a new file name so you can always go back to an old tune if you screw it all up.
Is your launch control setup for fuel cut or spark cut? Does it actually kill the pump (doesn't prime when you turn the key on) or does it just not fire the injectors?
Post by 93lxturbo on Jun 10, 2010 21:41:11 GMT -5
i will try doing the cold start stuff i will keep you updated. i will probably not figure it out
the launch controller is set to both fuel cut and spark cut, but i can put from all 3, from my end it work fine i thank but it works with and with out the 12v switch, and when i shut the car off it want start back and it just doesn't prime when you turn the key on..
its looking like i need to haul it to were someone know what there doing
Post by Stinger on Jun 10, 2010 23:25:38 GMT -5
Well clearly if launch control works with or without the 12v switch, you've wired it wrong. You using a relay? All you need to do is see whether it's getting 12v regardless of switch position. Odds are it is.
As for the cold start, an attitude like that will certainly keep you from having the motivation to succeed.
Post by 93lxturbo on Jun 11, 2010 7:22:10 GMT -5
I have a light set to the ms wire so when it get 12vs the light will come on so the ms wire is not getting 12vs until i push it. its not on a relay.
Post by Stinger on Jun 11, 2010 12:16:41 GMT -5
Does launch control work properly when running?
Post by 93lxturbo on Jun 11, 2010 12:24:53 GMT -5
i going to say no, scoot haves the ms as of now i fried the processor.. he looked over it and said i there was alot not right. something about the port was not right. he said he set it right. i will get it back around the end of the week and i will see
