Post by Stinger on Dec 14, 2011 14:29:44 GMT -5
Post by 84mustang on Jun 7, 2014 22:03:25 GMT -5
So does the voltage pulse?
Post by Stinger on Jun 8, 2014 18:50:05 GMT -5
No, the check engine light flashes.
Post by 84mustang on Oct 18, 2014 19:45:00 GMT -5
So is this koeo or koer? And what is the purpose of the meter?
Post by Strangeleak on Oct 18, 2014 21:22:38 GMT -5
This is for both tests. One of them delivers codes when they key is turned on. The other delivers codes when the engine is on. The ECU will rev the engine to about 3000 for 30 seconds or so then idle down and begin flashing codes. The analog meter is used to see the "flashes". You can also watch the check engine light for codes.
Post by 84mustang on Oct 18, 2014 22:15:01 GMT -5
OK so the meter will pulse? And I'm guessing that its for vehicles like mine without a light
Post by Stinger on Oct 18, 2014 22:39:02 GMT -5
Yes, the meter will pulse. You need an analog gauge though, not a digital gauge.
Post by rustybuttrusty on Apr 28, 2017 13:20:21 GMT -5
Is there a way to clear memory codes without a reader? I have a reader coming in the mail but I have no patience.
Post by Stinger on Apr 28, 2017 14:14:50 GMT -5
I think disconnecting the battery for 30 minutes will clear the "active" codes.
Post by rustybuttrusty on Apr 28, 2017 14:18:16 GMT -5
Thanks a bunch. Can you explain CM (continuous? memory)?
Post by Stinger on Apr 28, 2017 18:25:56 GMT -5
It's just historical error codes from the past.
Post by stocker on Jun 16, 2022 20:28:04 GMT -5
what if the car has no plug? my sons car has no diagnostic plug any chance you could tell me what pins they are? thanks
Post by Stinger on Jun 16, 2022 21:30:19 GMT -5
It's got one if it's a factory EFI car and it's got a stock harness unless someone removed it (not likely). Pins depend on the application.
Post by stocker on Jun 23, 2022 10:06:42 GMT -5
no this harness was made by someone, it has only the pins that were necessary for the car to run! it was in a pinto or so i was told when i acquired it in a parts package deal! ill have to dig up some schematics and trace them down! thanks
