kdog
Microsquirt Premium
Post by kdog on Mar 10, 2017 14:56:38 GMT -5
I'm building a 68 MGB with a 88 turbo coupe motor, trans and insterment cluster. I was looking at the Mega Squirt/ Spartan2. It's a stock rebuilt motor, .15 over, 90 deg intake, header with external waste gate, 2.5 In front mounted intercooler. I don't want to go to crazy with this thing, just want it right. Just wanted to know if I can get rid of the VAM, does it have the relays, does it have outputs for my gauges? what turbo would I go with? Thanks! Kdog
Post by Stinger on Mar 10, 2017 22:40:51 GMT -5
Are you talking about the PiMPx (Megasquirt 3 based) with a harness or the MicroSquirt with PNP harness? Both delete the VAM and have relays/gauge outputs.
kdog
Microsquirt Premium
Post by kdog on Mar 14, 2017 5:58:23 GMT -5
I'm sorry, the mini squirt, I don't plan on racing it or doing many more upgrades.
Post by Stinger on Mar 14, 2017 12:03:53 GMT -5
Yes to all of the questions.
Note you can't run stock low impedance injectors with the Microsquirt so you'll need to look at our 60lb units as well.
Turbo depends on power goals. If under 265hp at the wheels, the stock turbo is the best option.
kdog
Microsquirt Premium
Post by kdog on Mar 14, 2017 12:20:20 GMT -5
I have a header with external wastgate
Post by Stinger on Mar 14, 2017 13:22:22 GMT -5
OK, that doesn't really have anything to do with any of the info above.
kdog
Microsquirt Premium
Post by kdog on Mar 14, 2017 13:26:37 GMT -5
It raises the turbo up higher, hope to use it ,the waste gate actuator is real tight to the fender well on the stock manifold
kdog
Microsquirt Premium
Post by kdog on Mar 14, 2017 13:34:31 GMT -5
Also, I need to repair or replace the turbo anyway, 30 years in Michigan didn't do it any justice Would like something more efficient and up to date. wouldn't mind getting rid of the water lines either.
Post by Stinger on Mar 14, 2017 14:19:48 GMT -5
Using the header is fine but it doesn't change turbo requirements.
Rust on the outside of the turbo obviously doesn't hurt function but if you're wanting something new for aesthetic purposes, or just to eliminate water lines, expect to spend at least $650 for one that's not Chinese. I still can't suggest a turbo as I still don't know your power goals.
Post by Jbr32 on May 7, 2018 16:45:30 GMT -5
I bought a pimpx and turning software. What else do I need to make it work with my svo? I was told by email that this kit would get me up and running but now I see from this form that I need a wideband o2 and new injectors too. So what parts do I need exactly.
Post by Stinger on May 7, 2018 17:13:56 GMT -5
PiMPx doesn't require new injectors, though you'll likely max yours out rather quickly once the stock ECU/VAM is removed.
I don't know whether they gave you everything it comes with originally or not (USB drive, Cable, MAP hose, jumpers) so I can't say what you need, other than to say all of that stuff is required. If they already registered the software then you need the software license as well.
Wideband is also required. We sell the Spartan 2 wideband controller with sensor on our site with or without a gauge.
You'll need to actually create an account on this forum to view the PiMPx section.
