Post by J Coyote on Mar 1, 2018 19:48:54 GMT -5
Post by Stinger on Mar 1, 2018 23:54:31 GMT -5
350hp @ 22.7psi is nothing to be ashamed of!
Where was it dyno'd at?
What's the mods?
Nevermind, found it posted elsewhere: 2.3 Ford Turbo Pimp system Stage 3 Boport Head, Stage 3 Boport Cam, Adjustable Cam Gear 65mm TB, Gutted rotated intake Turbo Joe Custom Fuel Rail Adjustable fuel reg 80 lbs injectors, 255 walbro pump Holset Turbo, custom Centermount Header FMIC, 38mm wastegate. boost @18 stage 2 @22 HKS Bov Msd 6al Msd Coil Stinger 3"Exhaust
-Transmission World Class T5, Husrt Short Shifter, Spec 3+ flywheel Spec 3+ clutch one piece driveshaft 8.8 solid rear w/373 posi
-Interior Bride racing Seat g force 5 point seatbelt harness Autometer gauges Aem wide band pioneer head unit 12'pioneer sub woofer 500 punch amp
-Suspension Omp upper n lower front strut bar Omp upper n lower rear strut bar Front Adjustable Coilover (500lbs) Rear springs (700lbs)
-Wheels n Tire's 10th anniversary sve mustang rims 17x9 Front 225 45 contisport 17x10 Rear 255 40 contisport
-Brake Front PBR calipers 12' front rotor Rear drums
Post by J Coyote on Mar 2, 2018 8:08:12 GMT -5
Yea thanks I’m happy with it,Mike from Revolution Automotive here in Baltimore (Rosedale) was impressed with it too weighting just under 2900 lbs (with me in it) & running stock block so tuning was Conservative.
Thanks again for the recommendations.
Recent upgrade: Pierburg electronic boost controller (ditch manual 2 stage BC)
Future upgrade: Rebuild block 124lbs injectors 🤔 2step
Post by Stinger on Mar 2, 2018 15:34:07 GMT -5
I wondered if it was at Revolution since I saw the banner on the wall. They are one of our preferred tuners which is why I asked.
Post by J Coyote on Mar 2, 2018 17:36:26 GMT -5
You guest right I had a A+ experience really nice and knowledgeable guys I see why you prefer them looking forward returning.
Post by Stinger on Mar 2, 2018 19:18:47 GMT -5
Mike has a PiMPxs on his fox body Mustang.
Post by J Coyote on Mar 2, 2018 20:19:32 GMT -5
Yea Mike showed me when giving me a tour of the shop pretty neat Mike has a lot of things going on but hey listen about your stinger n pimp clothing gear are you looking to release or offer hoodie (pullover)cause I would be interested in grabbing some figure I ask
Post by Stinger on Mar 3, 2018 0:51:10 GMT -5
I'm not looking to sell them on the site and the place that makes my normal shirts requires a minimum of 30. I can provide you with the files to have them made on one of those sites that will print shirts one at a time for you if want though...obviously only for personal use.
Post by karl on Mar 9, 2018 17:20:24 GMT -5
22.7psi...pump gas?
how big of intercooler?
intake temps during the pull?
Post by J Coyote on Mar 11, 2018 18:10:29 GMT -5
My IC is a bar & plate 29x12”/3”thick and yes pump (93 oct.)as for intake temp the tuner told me when I was there but I don’t remember the number still waiting for the email from the tuner (revolution Automotive) with all the info and pulls from the start will post when I receive.
bmf347
Boosting 15 psi
Post by bmf347 on May 10, 2018 21:47:39 GMT -5
Sounds great in the video. Nice setup!
Post by J Coyote on May 31, 2018 17:51:50 GMT -5
Thx.
