Post by cperry42 on Jul 29, 2020 17:17:44 GMT -5
I cannot begin to explain how awesome this setup is. And if you actually follow the instructions you should have zero issues. Does it take time? Yes. But nothing great comes easy. I’m just starting the learning process of tuning, and I’m super excited. I put about 25 various miles on tonight allowing my car to learn itself without boost. Stinger and gang, you’ve done great. Can’t wait to start giving her hell.
One minor thing I will point out. Stupid me cut the ground wire pin 46 for the o2 wire. Which caused no TPS feedback. Just an FYI, maybe you guys can add to tap into that circuit.
Post by Stinger on Jul 29, 2020 22:05:40 GMT -5
Good to hear you're happy with it and enjoying the process so far.
Thanks for the feedback. It does say "The rest of the wires are not cut because they are shared with other sensors so you’ll “T” into them so they remain connected as-stock and you’re just sharing the ground wires. Crimp or solder these connections" in the guide but it's after all of the wiring info so I edited it a bit to make sure that point is clearer.
