Post by perri2300 on Aug 1, 2021 18:36:23 GMT -5
Gnari manifold= $200-Sold
Stinger flip adapters= $100
LB3 PCM= $60
The Gnari manifold was used in combination with the Stinger flip adapters on my engine for only a short period of time. I decided to remove the manifold and flip adapters because there seems to be an unavoidable exhaust leek when this manifold is used with the flip adapters. There is absolutely nothing wrong with the Stinger flip adapters, it just seems like there are some porting issues with the Gnari manifold that cause the countersink on the flip adapters to over lap the exhaust flange that results in a leak. The rest of the runners on the manifold are not lined up perfectly either in the flipped orientation. I think the manifold will function perfectly when used in the stock orientation without any exhaust leeks.
I also have a LB3 ECM for what I believe to be for an 88 automatic TC.
If anyone has any questions or wants pictures, I will be glad to explain further and provide visual information about the Gnari manifold, flip adapters, and LB3 ECM. My number is: (727) 314-4035. Feel free to call or text me any time.
Post by xr2300 on Feb 2, 2022 1:32:35 GMT -5
Is the manifold still available?
Post by plowboyz on Jun 19, 2022 17:11:16 GMT -5
Had this same problem with factory i believe e6 manifold you can fix it for 8 cent and exhaust silicone
