Post by Stinger on May 19, 2010 22:08:33 GMT -5
Also, a lot of you guys were asking when I'd have the larger injectors back in stock so: Fuel Injectors are back in stock! We now have 55, 75, 85, 96, and 120lb drop-in fuel injectors in stock! www.stinger-performance.com/universalparts.html
Post by denz on May 20, 2010 21:19:02 GMT -5
Nice now to finnish saving.
Post by jetfast on Nov 30, 2015 17:00:32 GMT -5
what is the largest injector the pimp will support?
Post by Stinger on Nov 30, 2015 17:40:34 GMT -5
There is no size limit.
Post by 87tbird on Mar 25, 2016 11:35:22 GMT -5
I bought some injectors from you a while back. I was wondering if they are flow tested or anything. I was thinking of having them tested to eliminate them as a problem to me blowing my second head gasket. They only have about a thousand miles on them, so I don't want to do it if they are all ready tested at the factory.
Thanks Matt
Post by Stinger on Mar 25, 2016 11:58:45 GMT -5
We only flow match the new FID injectors, though the ones in this listing are still going to be within 2% or less. There will be a much greater airflow difference cylinder to cylinder on your engine than there will be fuel flow. Blowing HG's is 70% of the time the tune, 15% of the time a warped deck/head, 10% of the time improper head bolt torque, and probably less than 5% of the time a fuel flow imbalance caused by injectors.
Post by 87tbird on Mar 26, 2016 19:13:10 GMT -5
I'm more concerned about the possibility of one of the injectors being a little blocked up with some dirt or something. Everything was brand new when they were installed, including the fuel filter. What do you think the chances are of that? Or would it be real obvious if one was blocked up or blocking up?
Post by Stinger on Mar 27, 2016 1:34:26 GMT -5
It's possible but not likely. There are multiple filters and screens to prevent that from happening.
Post by onebadstang on Aug 11, 2016 4:56:46 GMT -5
Do you guys offer smaller injectors too like 42lb for a 5.0 mustang?
Post by Stinger on Aug 11, 2016 8:57:30 GMT -5
