Post by merc460 on Jul 13, 2010 9:00:54 GMT -5
I have a Esslinger water pump in very nice shape comes with a modded Serp pulley. Sold I have another LA3/big vam Injector package the Vam as been opened up for blow through the LA3 has been opened up for a Chip and the injectors are 36lb CFI all worked very well together $120 Shipped And Finally a Boported Lower Intake a very nice item, the work is flawless $300 Shipped
Post by bobbarker on Jul 16, 2010 0:03:38 GMT -5
With the VAM what does it mean opened up for blow through? and is that a good upgrade set up with the computer and larger vam and injectors over a stock 85 SVO comp/vam/injectors?
Post by merc460 on Jul 16, 2010 8:26:51 GMT -5
What that means is I the plastic top is removable. This was done to tweak the vam spring and get the Air /fuel right for when I ran the vam in blow through. But I marked the original position so the vam could be reset to factory. Your 85 uses a small vam so I guess this would be a good upgrade?
Post by merc460 on Jul 17, 2010 20:46:28 GMT -5
Water pump Sold I will split up the La3 and Vam
Post by bobbarker on Jul 21, 2010 11:10:57 GMT -5
Why is this set up for sale cheaper than the other VAM and LA3 w/o injectors you have for sale? Which would be better for me? Are both set up's a "plug and play" kinda thing?
Post by merc460 on Jul 21, 2010 14:08:01 GMT -5
This one is cheaper because I opened up the Vam and opened the La3 case making them in my mind worth less than the unopened Vam, and the injectors are a bonus. They are both plug and play but you may have to play with the vam spring on the one I opened because as stated it is set up for blow through.
Post by bobbarker on Jul 22, 2010 17:15:04 GMT -5
Is that lower intake year specific or will it work on any year? Would I need to buy a ported upper to make it work or would that just be added power to the whole thing and the lower will work fine with a stock upper?
Post by merc460 on Jul 23, 2010 8:37:21 GMT -5
This lower is an 86 so it has no provision for the air temp sensor To take advantage of the way this intake is ported you should run a gutted upper and a ported head. If you ran a stock upper the upper would be the bottle neck.
