Post by 79turbostang on Jul 28, 2010 10:59:27 GMT -5
got an all stock 84 svo just wanting to turn the boost up alittle. I got to hook up my boost controller take a test drive and its wanting to boost like 25 psi with the controller turned off is there a special way to hook the up since its got that boost controller solenoid or should i adjust the wastage at the bottom
Post by Stinger on Jul 28, 2010 22:06:51 GMT -5
What do you mean by "turned off"? A boost controller should have low boost (screwed out) and high boost (screwed all the way in) and then everything in between. If it didn't have this problem with the stock boost control, you most likely installed the controller backwards.
You can verify the wastegate actuator isn't bad by blowing through the hose that goes to it (under the turbo). If you can blow through it, it's bad. If you can't, it's functioning properly.
What kind of boost controller did you install?
Post by 79turbostang on Jul 29, 2010 15:17:51 GMT -5
it just a eBay boost controller i got for like 5 bucks but u just figured out the problem on the controller it says for less boost screw in for more boost screw out so the product is backwards
