Post by stangfrk23 on Aug 29, 2010 11:43:17 GMT -5
any suggestions on a eec code reader? Been thinkin about getting a Innova 3140.
Post by FRANK/TurboTempo on Aug 29, 2010 14:18:47 GMT -5
for code reading you can pick up a snap-on scanner on ebay for real cheap and it does alot more then just read codes. its the snap-on Mt-2500 its very good its what I use till well now mine is updated till 2003 but you don't need that to scann a 1988.
you can even set timing with it and look for wirering problem.
Post by Stinger on Aug 29, 2010 14:22:05 GMT -5
I think that's a bit overkill, a $20 EEC-IV code reader from any parts store is more than sufficient. Technically you can do it with a paper clip if your check engine light works.
Post by stangfrk23 on Sept 11, 2010 17:35:27 GMT -5
well finaly got my code reader and the codes I got are 81 82 83 84 seem like all egr codes. Will this cause the low speed miss.
Post by Stinger on Sept 13, 2010 11:09:20 GMT -5
No, that won't cause a low speed miss.
Post by Stinger on Sept 13, 2010 11:10:56 GMT -5
Do a system pressure test to 20psi.
Post by stangfrk23 on Sept 19, 2010 17:36:56 GMT -5
OK so I ran the koer and got codes 25 34 37 43 47 54 4 is this pointing at a bad vam? did the pressure test at 20 psi couldnt hear any leaks. thanks again stinger. And those blinky light obd readers kinda stink. To easy to lose track of the flashes and beeps.
Post by Stinger on Sept 19, 2010 23:42:55 GMT -5
You sure you counted the beeps/flashes right? Half of those aren't even valid 2.3 codes.
On new turbo swaps, vam codes typically mean wiring issues, not actually a faulty vam.
